Top of MTX tranny leaking?
trainguy1989
SHOtarted
Wichita, Ks
I have a tranny leak on my MTX. It is not from the axle seals. Its on top of the tranny. The VSS, lower speedometer and part of the upper speedometer cables are covered in red fluid. Is there a vent up there? What should I be looking for? :thankyou:
trainguy1989
SHOtarted
Wichita, Ks
I had the tranny out of the car to replace the clutch. The tranny itself is fine and had no cracks on it at all. I could see the diff pins when looking throuth the hole where the axcles go. How do you replace a VSS seal? Do you just replace the VSS?
Thanks guys
Siman
Location Location
i know a SHO that has an extra one that will be again getting new everything that is sitting a certan yard but you know that just my thought train.....lolz and swing by i got some stuff you can HAVE....
zak
east of Hartford
This happened to me. If it is not the speedo gear O-ring, then it is likely the case halves where they meet. The ring gear flings trans fluid up to this location (ports inside take the flung fluid and use it to do a low pressure feed of the bearings).
Clean the case halves on top using brake cleaner. Take it for a highway drive (higher trans "pressure"), then check to see where the leak is (more towards the firewall than the bellhousing). If its leaking there clean it it again with brake cleaner and rags, get it very clean. Use ~ 240 grit (or a little coarser) to sand both halves. Then carefully spray two coats of Permatex gasket aerosol coating on (wait for the first coat to get very tacky first). Will try to get the exact product name off of the can tonight.
This leak appeared for me after I had a professional shop install my Quaife into my trans which was out for clutch replacement, then the leak appeared after a dyno session (7000 rpm in 4th gear = lots of trans pressure). Was able to limp it along using the technique above for roughly 80 K miles until it was finally time to replace the clutch again, and install my NESHO Gen III subframe conversion. The second time I split the case myself, carefully cleaned off the mating surfaces and then resealed using anaerobic sealant. Presto, no more leaks, even after hitting 110 at NHIS and somewhat higher on the old course at Lime Rock.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
I have been busy at work to day train, but I will call you later.
Most likely something with his speedo cable. There was zero evidence of any leaks at the case halves. My guess, you just need to tighten the lower speedo cable.
trainguy1989
SHOtarted
Wichita, Ks
The o-ring was missing in the VSS allowing fluid to pass it. I bought a new VSS cleaned things up and put the Syncomesh back in it. Shifts soooooo nice!
Thanks
Toolman
Boost it!
Excellent to hear! I look forward to having you back at the house for a SHO meet! Once I get the track car running, I will plan a meet, like a bar-b-q or something.
