Tool For TOKICO
artsho
New York
headbang I'm installing new struts and springs and can't find the correct tool for holding the strut rod while installing the nut......I have a strut installation tool kit, but it doesn't have this size.....Anyone know what size it is.... headbang .
artsho
New York
huh It appears you have never assembled SHO struts.....A crowsfoot will NOT work huh
SHOTIME
Giver of life
Boston Ma.
when using a crows foot on a torque wrench, make sure you use it at a 90 degree angle. otherwise it becomes and extension of the wrench and your torque setting is off.
shojuan
sunny San Juan Bautista,
artsho:
Not on 1993 and newer SHO's the nut sits way down in
That's what an extension bar is for.
SHOTIME:
Your torque wrench manual should (at least my craftsmans do) have a section on extensions which gives you a formula you can use to make a correction.
Torque wrench newbies! :p
DHMag
Free At Last
InCahoots, Texas
i have a Snap-On wrench combination (open and box), 21mm. the boxend has been heated and bent *JUST* for Taurus struts. been used at least twice that i know of, fixing to be used again. wanna see a pic ?
DHMag
Free At Last
InCahoots, Texas
lets see if this works...its not the best pic in the world...i still havent figured out my webcam software...
well ****..cant get the image to stay posted...check out this link ---->> here
<small>[ December 13, 2003, 09:26 PM: Message edited by: DHMag ]</small>
Mr Anonymous
Tire Wall
artsho:
artsho:
Thers no room for a crows foot.....Just a socket
Hmmmmm.... How many set of SHO struts have YOU actually assembled and installed???
I've done AT LEAST 8 sets that I can count off the top of my head, probably closer to double that amount, and have ALWAYS, SUCCESSFULLY, used a crowsfoot every time, regardless whether they were new stock, police, or aftermarket mounts, on all 3 generation SHO's and Tauruses.
The only possible scenario I've seen where a crowsfoot might not work would be on some old stock rear mounts there might not be enough room, but who would be foolish enough to spend good $$$ on new struts & springs only to reuse an old stock mount?
pjtoledo
'ol man in the SHO
toledo,ohio,usa
DHMag:
Does it look like a Flank Drive, box, deep offset wrench?
Perry
DHMag
Free At Last
InCahoots, Texas
pjtoledo:
DHMag:
Perry
it looks like a heated and uniformly bent Snap-On combination wrench.
