Mossdahaus
Well im taking the SHO in to get welded in a couple weeks and replacing the plugs too. I want to clean out the intake runners and surge tanks but have no clue what to use. Should i use a engine cleaner with them on the car or use some kind of de-greasing solution and run it through them with them off while being welded? Also, what are you guys using to insulate the main wiring harness from the heat? How hard is it to take off the IMRC...will i need new gaskets if i take it off? How do i clean that? If you guys could help me out with all this, it would be great!!! Thanks!
