tires/wheels/suspension
NotoriusCSR
colorado springs, colorad
im about to get tokicos, eibachs, and poly bushings for my sho and before i have them installed im wondering: with the new lowering rate of the springs and the stiffness of the tokicos will i need to have the camber rate changed or will the effects be too minimal to warrant a change? i dont want to get a new suspension just to have it mess my tires up.
also, after i get these im either getting anti-sway bars or subframe connectors, which would you guys recommend?
RStalveyARFF
too many shos
Georgetown, MA
The camber will definitely change, by how much I do not know. SHO Shop sells a camber kit, it's a set of plates I believe. Between ASB's and SFC's, I'd go with the connectors, since your car will get a more noticable improvement in handling.
Erik
15.57 @ 93.23 and 15.58 @ 92.73
White 91 Bought 5/12/01 128.5k
Mods:
Borla Catback custom bent by Lou's Custom, Cold Air Induction, Clutch, PP, TOB, Pin just replaced, DIN sized switch panel (replaced cup/coin holder), Fog Light Mod w/ 100w driving lights, Lettering filled in: Black, Nokya 80/100w blue beam headlights(Thanks SHOTIME), Painted calipers: Red, Painted intake: White tanks/Black runners, PermaCool dual 12" Electric Fans, Police Grille, Police Interceptor Emblem, Resonator Removed(not by choice!), SHO-NUT Reinforced F & R Motor Mounts, Shortened Shifter, Superchips Module(thanks SHOTIME), Tint @ 35%
Every Possible Option =)
Go Fast With Class
AIM:SkiSalomon & SHOmetheSpeed
T
ThatSHOkid
Guest
i was wodnering how much are u spending on these because i am possibly thinkign of upgarding the suspension on my car and just want to get soem estimates. thanks
1993 White/Tan SHO MTX 95k Miles
[*] Superwhite headlights, reverse lights, and license plate lights
[*] Colgan custom bra from Cincy SHO
[*] Windshield Banner that says "SHO" in Gen. 2 font.
[*] Superchip
[*] Blacked out "SHO" lettering
[*] Sho Shop Y Pipe
[*] Coneless & boxless
[*] Blazertech Super Clear 55w Foglight upgrade
[*] Sunroof Wind Deflector and Vent Guards
[*] Sony 10 Disc Changer
[*] Coming Soon:Tinted Windows, Cold Air
[*] All Possible Options
[*] AIM: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
fredhurderjr
www.neshospecialists.com
Mine this year:
Eibachs, $260
Tokicos, $500
SP Motorsports
Subframe Connectors: $65
Spoolit (under the "where are they now files..."
Front 24mm ASB (not used yet), Rear 26mm ASB - eBay I think, $140?
Poly ASB bushings, front & rear $30 (both or per set, not sure)
Rear endlink kits (2), $14 ea.
SP Motorsports
Front & Rear STBs, $200, Kev "LSC Power, dude!" Schofield
That's about the $1220 ballpark for everything, less labor for the springs & struts, and the $40 to weld in the connectors.
NotoriusCSR
a friend of mine is sellin the eibachs for 165, tokicos for 450, and bushings for 50. all never used. he had a sho, gave it to his bro, who then blew the engine while tweaking it so the suspension never got used and now im pickin it up.
forcefedperformance.com has tokicos for 125 a piece.
AutoXSHO
Glenwood, MD USA
Man, Fred, who's welding them in for $40?
I had two shops quote me on it. One is run by a friend of mine who does SFCs for mustangs. He said it's a piece of cake but to do it properly with a series of hot tack welds, plus surface prep to remove the undercoating, plus painting and undercoating he quoted three hours.
I suppose if you have a wire wheel and can clean up the undercoating yourself...
My Tokicos were $80 apiece a year ago. The eibachs were $230. Rear 26mm bar was $50. SFCs will be about $40 for the connectors, and .. $140-160 to get them installed.
John V
95 MTX with mods.
