tire/wheel combos
93blackatx
Boston, MA
im looking to get new rims and wheels. im looking at two different wheels, 17x7 and 17x8. right now i have the slicers with 225/60R16 firestone tires. the tires are too big and are rubbing the spring and look HUGE on the car, would 215/40R17 do the trick with the new rims, any feedback would be GREATLY appreciated. thanks.
kaoticSHO
Thread Killer
sitting upon the Grimpon
My setup is 38mm offset, Team Dynamics Touring rims, 17x7.5 I run 235/45/17 with no rubbing at all.
93 atx, a few mods
www.picturetrail.com/kaoticSHO
1992blackmtx
cleveland,ohio
with 215/40-17s you would have a huge fender gap unless your car is lowered, if you get 17x8 i would go with 235/45-17s, if you get 17x7 your tire selection is more limited, most people run 225/45-17s, however 225/50-17s will keep your speedo the most acturate but you selection will be very limited with that size.
RI-SHO
B to the BANNED
Pawt., RI
Rubbing with 225's? My 225/55/16 Yoko's for my Slicers dont rub niether does my 18x8 TD Motorsports with 235/40/18 rub. I would go with 1992blackMTX suggestion because if you get 215/40/17 you will need at least 3+" drop just to make it look decent
Click To See My Modified 1993 MTX SHO
thatSHOguy101
