timing belt
josh m kuhn
wisconsin
I have a 93 mtx and i dont know when the timing belt was last changed or if it ever has been changed. I dont know how hard it is gonna be could someone let me know how hard and long it is gonna take
Ishodu
Its not a hard job at all. If you go to the link in my sig about the ECC codes you will find a web page that has step by step instructions on how to do it. Under front 60K.
TYSHO
Earth
Exactly, just a little time consuming.
Also, if you do not want your middle timing cover to break in half, it is best that you remove the four 12mm(?) bolts to remove the waterpump pulley.
KyngofPop
Freday-day
Charlotte NC
The first time I did my timing belt it was a very time consuming and frustrating job that took about 9-10 hours. But after you do it once, each time thereafter will be a cakewalk. I used the directions on SHOtimes.com which were excellent.
