CWhalenSHO
I finished buttoning up my front 60K last weekend. It started up fine but I think I might have either tightened up the Timing Belt tensioner too much or the acceessory drive belts too much.
When I started it up, it sounds like it was whining from the front of the car and it was whining got louder as I gave it a little gas.
So, can you over tighten the timing belt tensioner or acc. drive belts too much? I'm assuming that they can. Is there any specs or directions available as to how tight these tensioners should be? I followed the SHOPhoenix website to the letter when doing the front 60K.
Oh, BTW, I also had the check engine light come on when I first started it up.
