I have two mysterious noises coming from my engine bay...
The creaking noise happens when I turn left (the noise is in the left side also) when I am stopped.
Another thing is when I start off, either backing up or forward. I makes a "thunk"ing sound, once. each time I start off. It happens eaiser if I am going in reverse...going forward I have to give it some decent pedal for it to happen.
I checked the engine mounts by parking and easing on the gas with the brake on...and (unless you need to put a lot of pressure) the engine doesn't move much at all. but underneath the joint where the exhaust is connected...seems to be moving quite a bit ????....any thoughts ??
