Thrust bearing bad news/ good news.
Racer X
SHO Pilot, Retired
Connecticut
The bad news:
I found a little bit of bearing material in my oil pan when I pulled apart my engine today. After finding 12 healthy rod bearings and 8 healthy main bearings, I was admittedly confused.
Then I looked at the thrust bearings...
P1010012
The good news:
I saved the set from my 3.0L, which were in great shape. In fact, at almost twice the mileage, everything on that engine was in better shape than this 3.2L. But I digress...
Before I toss in the new bearings, any ideas on what might cause wear like that on thrust bearings? I've been dicking around with these cars going on 6 years, and I've never seen or heard of a thrust bearing going bad.
Thanks all.
- H.
hawkeye18
Sorta cares
Norfolk, VA
Whoa. What the **** happened to those? I agree, this is certainly the first case of bad thrust bearings I've heard of.
Racer X
SHO Pilot, Retired
Connecticut
The ATX single belt damper that came with the engine.
I have a 3.2L in my MTX.
Racer X
SHO Pilot, Retired
Connecticut
The transaxle facing bearing.
I've never had anything bigger than a Stage 1 clutch in this car, and before that, there was an ATX behind this engine.
*edit*
Current clutch is a Southbend Clutch (DxD) Rally Series Stage 1 clutch. Prior to that was a couple of AutoZone stock replacements. The first was good, the second had a PP defect. It was replaced by the DxD.
93rev2sev
Hockeytown
Is that 3 clutches in 50,000 miles? or 2? Was there throwout bearing damage or finger wear with either? If it's not the stiffness of the clutch, maybe you've been resting your foot on it?
(my earlier post assumed you just got this from an ATX. I didn't know you put 50k on it).
Racer X
SHO Pilot, Retired
Connecticut
The first clutch was a holdover from the 3.0L I swapped out. I was admittedly in a rush, and only did a rod bearing service, and replaced the TOB. The second clutch was a dud and only lasted 900 miles. The current clutch has been in since 9/07... I'd have to go to the car to check the mileage, but I want to say it's less than 15k on it.
That said, yes, there is finger wear on the PP. Nothing crazy like missing fingers, but it's there.
I never rest my foot on the clutch. Not even at lights.
Racer X
SHO Pilot, Retired
Connecticut
Isn't there supposed to be TOB pressure on the fingers? When you pull up to adjust the clutch pedal, the spring in the pawl introduces tension into the cable, which will apply the TOB to the pressure plate a little.
93rev2sev
Hockeytown
nope. When your foot is off the pedal, there should almost no pressure on the TOB. The weight of the pedal will keep it in contact with the fingers...but pressure? I would not call it that.
313tiger
