Throttle stuck open today
xshoel93x
SHO driver
Massachusetts
my friend said "toyota: moving forward even when youre hitting the breaks" i informed her it was brakes not breaks. she yelled at me. apparently she got rear ended by one last night
I had this happen on a dual side draft carb setup before, foggy and just above freezing.
If you just shut the engine off it takes about a minute for the heat soak to thaw it out.
hawkeye18
Sorta cares
Norfolk, VA
As noted in the post you linked, hawkeye18 is now in the top 2%.
http://www.shoforum.com/showpost.php?p=1225329&postcount=12:rolleyes:
Har dee har har. You got way too much time on your hands, digging old posts up like that!
Although I would like to point out that what I said I'd do if it happened is precisely what I did actually do when it happened. Right down to beating on it and twisting the spring by hand. No, I didn't think of that post when I did it.
yamahaSHO
E85 whore
Arkansas
Time? That search took all of one try and about 2 seconds to find. If you search smarter, the posts you're looking for will be in the threads returned. ;) I also knew what I was looking for.
Can't say I'd beat on the throttle though. I'd let the 200F+ motor warm it up after shutting it down. It also not something I'd do on my wife's car either.
tompumped
VT
This happened to me recently while driving to vt in a snow storm. It didn't get completely stuck, but I could definitely feel it in the pedal.
It too happened when I was at a steady rate of throttle for a long period of time. Stepping on and off the pedal a couple times got rid of it.
