Marccus
I need to replace those small metal tubing connections on the throttle body (and elsewhere where they are used for coolant and for PCV from the valve cover) because they are pitted to the point whre they show pinhole leaks and some are just disentegrating into dust.
How do you remove these connections from the throttle body?
Just yank them out?!
Do they screw out?
Do you have to be very careful when removing them as I believe the throttle body and the valve covers are made of a very weak material - *** metal (a low grade aluminum / zinc) alloy?
Where can you get replacement or do you have to fabricate your own?
If the latter, I guess you must find out a way to put a ridge on the tubing as the original has, so the hose can be clamped on without sliding off.
How do you install the new tubing connections?
Do you have to "glue" them in or are they anchored in place with jsut a snug slip fit?
Any suggestions appreciated.
Do they screw out?
