Those w/ Powder coated slicers
marvsho17
Joshua S.
rockford, il
Im getting my slicers coated black. What kind of prep is involved? Clean em w/ parts cleaner, and sand blast them? Is the sand plasting absolutely needed? And do I need to cover anything up on them?
40BelowSummer
Puerto Rico
Get a can of aircraft stripper to strip them, then I would recommend bead blasting or sand blasting them. The cleaner (more "stripped") the better for the powder coating.
SHOTIME
Giver of life
Boston Ma.
most shops thats part of the process.. so contact the shop thats doing it first.
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
Since they are made from aluminum they should be chemically stipped. If you bead blast them you will ruin them, and same thing might happen with sand blasting. It might be able to take it but I doubt, so just have it chemically stripped and you will be fine. I just had some rims that were made from aluminum (non-stock) and they had them chemically stripped.
40BelowSummer
Puerto Rico
Arent our intakes and valve covers aluminum?
If so I know hypercoat bead blasts them.
LOUDSHO92
Sponsoring Vendor
They are. I do not know what Hypercoat does to them. I know glass may work but it depends still on what aluminum and the glass used. I am going off of what they shop did to do mine. i asked them about it and they said this was the best way to make sure parts dont get damaged. I would guess that Hypercoat worked things out so that it did work.
40BelowSummer
Puerto Rico
Mike D. of Hypercoat said:
Step One: Disassembly of individual components. We must separate certain parts that can't go through the process.
Step Two: We then take your parts and give 'em a good bath in degreaser.
Step Three: After the parts are thoroughly cleaned of grease and dirt we bake the parts to evaporate the moisture within the metal.
Step Four: Following adequate cooling the parts are blasted to bare metal using glass beads.
Step Five: High pressure air is used to blow off the parts to ensure a quality finish.
Step Six: This is the really fun part! We take your sparkling clean parts and apply a positively charged powder to the negatively charged metal.
Step Seven: After coating the parts are place in the oven at 450 degrees for about 30 minutes until cured.
Step Eight: After cooling the parts are reassembled and shipped to you.
yamahaSHO
E85 whore
Arkansas
Everyone here already has good advice... no need for me to comment ;)
LOUDSHO92
Sponsoring Vendor
I dont argue that but in some cases it is not the best case. Aluminum is a soft metal and does not always responds well to that kind of thing. Just because it says in on the site, measn they do it to everything anyways.
SHOnuff93
Dublin, Ca
Bead blast the aluminum before in order to make sure everything is off. The glass beads will not hurt the metal in any way. Also make sure you clean the metal after blasting it leaves alot of dust
