JRA2000TL
The Complainer
I just swapped my AZ reman alternator last night under warranty because I had the following issues:
1. Battery bought 11/10, charges up, tests good on my charger and AZ's.
2. Checked battery posts while the car was idling under a full load; voltage drops from 12.7 gradually downward very slow.
3. Made sure battery terminals were tight on battery, also verified that the lead (metal eyelet thing) on the back of the alternator was secured to the stud on the alternator itself.
4. Did a test I read about online where I disconnected the negative battery cable, put 1 voltmeter probe on the positive battery post and put the other on the rear stud of the alternator. Set meter to ohms and got a bunch of #s jumping around, went OL then 40-50 then .5 to 1, etc. I was told this is to check your fusible link. Results were inconclusive based on this erratic reading.
Both my old alternator and this new reman out of the box pass AZ's test. Both say "fault" on my battery charger when I test them while the car is running.
I get no battery light on the instrument cluster.
What else do I check? Where is the fuisble link and how can I check my wiring otherwise? I've gone as far as I know what to do. AZ told me if this one doesn't fix it that I need to address my wiring before they warranty out another one.
I'm tempted to take a $55 gamble and buy a used OEM one currently on Ebay just for the **** of it to see if it works since it's a Motorcraft and not AZ reman crap.
