This weekend
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
So this weekend i came back home from UWM, and had my car waiting for me when i got back home, that friday i went down to highway 100 just for a little fun :) me and my buddy found this white civic 3door that thought he was the coolest person, so when we finally pulled up next to him, i showed him what the difference was between an SHO and a regular taurus... he got a little chirp on the launch, and thanks to my new clutch adjustment, i was able to have the best launch i have ever had, minimal tire spin, but took off like a rocket.. it felt good... all without my secondaries
then Saturday, my secondary controller came, and i didnt realize the difference that these babies made above 4000 :)... wow, so we took my buddy's SHO down, (even though it needs a tuneup something fierce...) and met up with blownsho... talked for a bit and cruised the hwy for a bit and then headed back home... all in all it was a good weekend.... except the fact that my rear DS brakes are sticking... i hope its the flexline so i can get some SS lines... :)
SHOBabe
mmmm SHO
Milwaukee, WISCONSIN
glad to see everything is going good for ya dan,
wish i had off so i could have some down there, but NO i worked, and it sucked
Wht91+
93 Green MTX
Oconomowoc,WI
Yes I do agree....and work does suck. Dan when are we going to race?
Blwn SHO
SLOSHO
Pewaukee,Wisconsin
NO NO NO...The ? is. When are we dave.. I hope before the supercharger..But i know you sadi you want to after to see what it does.. :thumb:
Wht91+
93 Green MTX
Oconomowoc,WI
I will race you tomorrow. I will enjoy it. NO EXCUSES!!!!!!!!!!!!!! If there is don't even waste your time. I will give you a call tomorrow Jess.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
PSshh yeah so before i left for school again, i found out that my secondaries are staying open... so the statement of it pulling above 4k is correct, but i neglected the one about it being a slouch below 4k :( i guess its time to check continuity... hopefully i find a short somewhere...
Wht91+
93 Green MTX
Oconomowoc,WI
Check the plug on the back of the intake manifold. It is hooked up to a connector that has a 2" hose that goes to a Black plastic cylinder. If it is dissconected your secondaries will always be open. BIG loss in low-end power.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
are you talking about the 1 way valve? i just replaced the secondary controller... so all the vaccum lines are hooked up for sure... im 99% sure my problem is electrical
Wht91+
93 Green MTX
Oconomowoc,WI
Yep. Dissconect the like from the intake off that and see If you have a vaccum from the intake. If not check the vaccum lines off the secondaries...you could have a cracked T-fitting where they connect together. Otherwise I would have to look at it and well I really don't have a lot of time....I work everyday. Good luck otherwise.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
yeah... checked all that before... it has vaccum until after the secondary controller... i had some other type of vaccum thing on there that teh P.O. put on, and it gave vaccum all the time, so im sure theres vaccum, im positive that its the wiring leading to the controller
