Jersey Fred
I just replaced the CANP since that was the last code I was getting. For the first time since I owned the car it is finally throwing 1's.
A day or two later I noticed that there is an intermittant sucking noise through the TB. I dont think it is a vaccuum leak since secondaries are working fine and idle speed does not change at all when it kicks in. Sounds like a leaf blower inside the plenum - pretty damn loud. I removed the hose from the filter/MAF to the TB briefly to confirm it wasn't a whistling through the filter, clog in the line, etc. definitely coming from inside the TB/plenum. No clog in the nostrils and all connections on the plenum are tight.
Any suggestions?
Any suggestions?
