cali+Mocasho+
89 white 3.2 145k
out of nowhere i get locked out of my bottom gears 2 ,4 and reverse. did the tranny take a shit ? have a feeling theres no fixing this. feels like im locked out.
where do i start looking? thanks for the quick reply.You broke off something on your shifter linkage. Jack it up and look for a loose rod or cable bracket.
Tom
My sho is able to shift into all gears again. Weird I was so sure it was going to be like that forever. What could that be? I was on lunch when it happened out of nowhere,was forced to drive on only the top row of gears back to work. I parked it in neutral and went back to work for 4 hours came out and before i turned the car on I clutched and was able to use all gears. Drove home fine.You broke off something on your shifter linkage. Jack it up and look for a loose rod or cable bracket.
Tom
Yes. Pretty much every car I have had with a stick in it does that.Is it normal to be able to move the stick inbetween gears freely with out clutch. (while the car is parked,andoff?)
