this is getting out of hand
sho'd
Git R' Done
ontario,canada
well i had a new flex pipe put in today, and i put a new o2 sensor in the front y pipe, i am getting a code 172 now?? also found out that my drivers side front spring is broken. man i don't know if this car will ever get on the road. i used a NTK o2 sensor, it never had this code before, i havn't replaced the back one yet. i broke the front one getting the y pipe out. anyhow any ideas on what to do about that 172 code? this car is taking me way to long to get it on the road, it's driving me nuts! please help. thanks Mike.:cry:
Black '93
Guest
Lakemoor, IL.
Yeah, I have an idea- go buy a new oxygen sensor for your rear mainifold because thats the code for no good! Do a search next time you have a code to figure out.. They have all been talked about at one time or another.. A lot of people won't answer you for asking code stuff 'cause it's all availible if you use a SEARCH!
SASHO91
Zoom Zoom
San Antonio,TX
If its indicating lean, i would check for a vaccum leak... which is what 172 is for, a lean condition.
did you replace both sensors?
also, where was the code? Was it in memory?
I would disconnect the computer/eec for 30-60 secs. (pull the negative battery cable) then, re-attach, then drive for awhile. then pull the codes again.
wood_e
The dude
Ames, IA
I had a huge thread about my 172 code and it turned out to be my O2 sensor.
sho'd
Git R' Done
ontario,canada
ok well i have searched this out, just can't seem to find out what sensor it is, is 173 the front o2 or the rear o2? sorry for my ignorance
ohfosho
ontario SHOwner
ontario, canada
172 = right or rear O2 sensor not switching...replace that one now...normally you replace them together at the same time since you are already there.
sho'd
Git R' Done
ontario,canada
thanks, i replace the front one yesterday, so i guess i will have to replace the rear one. what a PITA.
SASHO91
Zoom Zoom
San Antonio,TX
I wouldnt be supprised if that code is still there with the new one.... i mean i hope it fixes the problem, but you cant automatically jump to that conclusion, all the time.
