Third Brake Light
Project24V
Duratec?
Pittsburgh. Pa
Well my Thread Brake light is burned out what do i need need to do get a new light bar for that? or can i some how get bulbs or somethin in their?
T.O_SHO
Power Hungry
Toronto, Ontario
You cant really get to the lights unless you crack open the housing by baking it. I don't even think it is possible to change just one LED, just because of the way they are set up.
Start searching the junk yards, and when you find one, make sure your able to return it if it has a burnt out LED, I tried 5 different brake lights until I found one that had all of them light up.
PCPackrat
SHO Geek
Seattle
I took mine apart using the oven to heat it up. I then bought 3mm superbright LEDs. They are in groups of 5 in 4 sections and are mounted opposite polarity in each group. If you heat is in an oven, be careful of the abs housing as it can warp at about 170 degrees.
