These 2 dont seem right (pics)
syP
GTP>SHO>*.cars
Wheaton, Illinois
From the shifter boss:
Axle seal out?
Racer X
SHO Pilot, Retired
Connecticut
I can't really tell with the intermediate shaft. Can you get a shot that's perpendicular at the seal to shaft interface?
And yes, your shifter boss is hosed. That'll need to be welded.
syP
GTP>SHO>*.cars
Wheaton, Illinois
No problem.. im buying a different trans that is "built" with the same problem ;)
engine/trans/subframe is coming out within the next month or 2 ;)
would the engine mounts cause the boss to break?
Kens1992mtxSHO
The Commonwealth
With the excessive movement of the engine it would cause the boss to break. Maybe some hard shifting during WOT had a part in it too.
SuperHO
Mental Patient
St. Joe, MI
It doesn't neccessarily "need" to be welded....I had the same problem, and I wound up crawling under mine, drilling a 3/4 inch deep hole in the existing hole (was afraid to go further), tapping it and running a bolt in there. Works just fine until I can get something that'll reinforce it.
1995mtxsho
Grand Rapids, MI
The shaft is pulled out because your carrier bearing has separated from the rubber that isolates the bearing from the bracket. The rubber bonds everything together and holds the shaft latterally. It may eventually slide out far enough to become unsplined. Start looking for a used one that is still good, as there is no replacement. Or figure out how to replace the rubber with urethane and remould it.
93rev2sev
Hockeytown
The intermediate shaft looks fine. Here's an example of a GREAT solution to the trans boss mount...
Enginelowerrear
yzstud
< my kawi
Minnesnowta
Enginelowerrear
I think you just wanted some of to be jealous of the underneath of that car
well.....................
It worked on me
SuperHO
Mental Patient
St. Joe, MI
To adress the original concern of the thread, check your motor mounts and the accessory bracket that holds your A/C compressor/altenator...make sure they're all in good shape. I've broken two, and both were the result of craptastic motor mounts. A length of chain has taken care of that problem quite nicely, I must say. After you get the motor wrenched down so that it stops moving, then you can either create something to use some of the other existing holes in the trans, or do the fix that I mentioned about 4 posts up.
93rev2sev
Hockeytown
I think that plastic thing is there so that when the factory jams the intermediate shaft into the trans during assembly, it doesnt go too far and damage the gears. It's in the correct spot from what I can see.
rocket455
Fairfield, Ca
i have the same problem with my intermediate shaft. does it cause yours to shift funny as well? and leak from there?
newby92
3.2 swapped 95
ohio
mine looks just like that as well, but doesnt leak and is actually seated firmly into the splines pretty far in so i ver worried about it, just figured it was the way it was supposed to be. it was that way on my old sho as well.
