Off Road SHO
Moderator
Dammit! I finally get her started and she has developed a bad engine knock. Curses!
I doubted my expertise on what was my first valve adjustment, so I pulled the intake and covers off of her and the as-left clearances are all within the specified range. So that's not it.
Then I had doubts about my rod and main bearing job I did on her so I pulled the pan, windage tray and girdle off of her. I've plasti-gaged 4 of the 6 rod bearings so far and all of them are at .003 which is at the large end of the range but still within the specs.
I had some bad gas and some two stroke mix also in the tank. I'm wondering if that would cause the knocking sound. It knocks from idle on up the rpm range.
Maybe my timing is way out and what I'm hearing is real bad advanced timing knock.
Anybody have any ideas?
Thanks
Tom
Thanks
Tom
