The famous "foglight trick" something to think about...
Camarok
Awesome SHO Member!!
Milwaukee, Wisconsin
Well unless I'm an idiot, I never found a subject on this so I'm gonna tell you :p
Ok... so you tap in to your parking lamp/dash display lights so you can have your foggies on with your parking lamps... and auto lamps...
Well, I just found out somthing that was actually pretty obvious. I was turning the dimmer down and suddenly my foglights turn off!! I'm like WHAT?! SO I turn the dimmer back up and they come on. Well I guess there isn't enough voltage/amperage in the lower settings to keep the lights on... has anybody else tried this?
.... ahh wait... i wonder if this has anyting to do with it... i've got aftermarkt lights with relays... u think that's it? It's possible I guess (look at this i'm talking with myself... and telling everyone) Well whatever, It does it in my car....
James Downing
Virginia Tech, VA
Stock fogs use a relay too.
Relays need a certain voltage to switch, once you get below the specific voltage, the relay turns off. Since the interior lamp dimmer changes voltage, the fogs turn off eventually.
Camarok
James Downing:
oh ya i understand that fully just that i never realized that it would happen oh
If you tap into the parking light circuit this will not happen.
SHOtimer
#2910
Santa Clarita, Ca
I followed SHOtimes instructions for my 'fog lamp mod' and I can play with my dimmer all I want and my fog lights don't react at all. I never would have thought that the dimmer would have anything to do with the fog lights. I was under the impression that all the dimmer controlled with the interior lamps.
Doug
autobahnsho
SHO Victim
NY for now, WY for real
SHOtimer:
Doug
But remember there is an 'interior lamp' IN the stock fog switch. So the dimmer does affect a certain wire. Wire it wrong and you get some funky results.. :D
I did what ShoZ123 said and am funk-less. thumb
