munkee
Too busy...
I went out to start my car at oh too early this cold morning and discovered several problems. At first it fired then lugged and died. I started it a second time and used a little throttle to keep it alive although it was lugging like it was missing quite badly. The throttle would jump back and forth @800 rpms every two or three seconds. After at least a minute it smoothed out to an even idle and then I turned on the defroster and it started acting up again for a short bit. Ditto on the stereo. Then I was driving in to Sioux Falls (seemed to drive fine) to get new tires put on and all of a sudden all the windows fog up and the heater is blowing really moist air. At first I thought it was the heater core but it didn't smell like it and about a minute later it cleared up again. Huh? Then after the tire change and on the way home, the fan would not shut off. When I push the off button it reads off but blows full hot on the defroster. Just when I though everything was going so well too. I just finished a full 60k and a new paint job about 3 weeks ago. The only item not replaced is the plug wires. I didn't get them ordered from IPT soon enough so I am driving it with the old oily wires until they are delivered. I don't personally think that the cold is too big a deal because it was 14 below all last week and I didn't have one problem with it, but who knows. It was 30 degrees warmer this morning. Could the plug wires really be the problem or is the alternator maybe at fault? Is it maybe a bigger electrical problem or is the problem with the heater just a coincidence? Any input is appreciated, and I will double check for codes later this afternoon. I am also working on the eatc problem in the search area. Sorry for the long post and if this would fit in the electronic section better, please move it.
Oops, almost forgot. 1990 MTX
<small>[ January 27, 2003, 11:45 AM: Message edited by: munkee ]</small>
