temp??
WhiteSHO625
il
hi i just got a 91 SHO and my temp gauge is not working what could be the problem??
most likely: the sender is bad, the connection on the sender is bad, or the engine ground is bad.
the upper radiator hose goes into an aluminum housing that looks kinda like a spider. on there are 2 temp senders - the one w/ 2 connections is the one the pcm uses, and the one with 1 connection is the one the gauge uses.
