TEMP GAUGE NOT WORKING...HELP
MikeM
Mount Clare, WV
Hope someone can help with this one. My temperature gauge just stopped working yesterday. Electric Radiator Fans still work. Can anyone tell me...
1. Where is the sensor for the guage located?
2. Is the sensor most likely causing this?
Thanks. Mike
Mr Anonymous
Tire Wall
MikeM:
Thanks. Mike
If your gauge is not moving at all, then it might be the gauge itself. If you are seeing some movement but it's not accurate it could be the gauge sender ($7.00 part) which is on the forward side of the thermostat housing.
