eli terry
When I first bought my 1992 mtx last fall the power antenna only went half way up when the radio was on then partly down! Well i did some investigation and found that the nylon toothed line was broken in half. A new mast was ordered and installed and worked like a charm until the car sat through a ice storm! Well then another mast was purchased and it once again worked like a charm! Then for no reason last week it extended fully and the motor kept on running. After inspection I found a broken area in the toothed line! So I promptly went to the nearest salvage yard and removed one of those spiral masts off a 1998 black taurus se. The mast was gloss black which now looks great on my black on black 1992 mtx sho. I don't really care that it is not a power antenna cause it looks cleaner and is just one less thing to worry about.
