The wipers dont work any more from the switch, the only way it works is if i have a turn signal on, thats the only way it would turn on, what do i have to replace?
Before you take it off. Spray a bunch of WD 40 into the e-flasher button. The work the switch through all it's motions. You do not need the car to be on.
If that doesn't help take the switch out and hose it down again with the WD. Then try it out.
