tach stuck
trevhelton
Yakima, Washington
Ok here the deal my tach is stuck at liek 2600-2850 rpms when driving it looks like I am driving at 3000 rpms in 3rd gear going 30. When I am going 35 it goes about 3500-4000 rpms. Tried gunning it to break it loose but it didnt help. Did this 2 or 3 times. Will check it agin in the morning to see it if returns to normal. Any help on this is greatly appreciated. If I need to find a new one what vehicle does it need to come out of. Thanks
Trevor :thankyou:
trevhelton
Yakima, Washington
Yes it does. But as soon as it fires up it going to toght 2600 rpm just the othe day I would idle around 1200 rpm.
Trevor
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
pull your cam sensor, let the oil drain out, and replace it and the cam seal there....
my car was doing this. cam sensor was dirty. it would just bounce from like 1500 RPM driving down the road to like 3000RPM.
Kalamazoo, Michigan
my tach kind of wobbles sometimes. It moves up and down fine but when i rev up sometimes it wobbles a little back and forth. not nearly as bad as my friends 83 hurst olds, haha that thing is crazy
JRA2000TL
The Complainer
Daphne, AL
Mine just got stuck under the peg from when my starter was going nuts and giving me all kinds of weird indicators on my instrument cluster. My tach went around clockwise and now it's stuck under the peg. Revving it super high in 1st and 2nd hasn't fixed it. I don't want to have to pull the dash fascia to fix it.
SHOmethewayhome
BAD ROLE MODEL
that's my favorite part about starting my car after i've been working on it and the battery has been on and off... for some reason the tach needle likes to end up under the stop needle. revving it up usually corrects the problem jeremy is talking about.
