tach install?
N
neg1ohs
Guest
okay i got a 89 and i dont know where to get the siginal wire.I tried by the rear strut tower nothing not a thing.Looked around and couldnt find anything.Help plz.
dantheman68
Kinda Big deal
Pewaukee, Wisconsin
dont you have a tach in the cluster?
there are several ways that you can hook one up... there is a tach service connector on the passenger side of the engine bay... in my 95 manual it says it is a T/Y wire with a black connector that is open on the end (tan/Yellow wire im guessing)
there is also another and that is the gray/orange wire that goes into the ICM...
those both should give you the tach reading... they are on the same circuit, just different wires, and one might be easier to find than the other... again these are also 95' wiring diagrams i looked at... so dont be surprised if you dont find the right color... although they should be the same in this case.
LeddZepp8687
The Keg Rider
Naperville, IL
Passengers side, against the firewall by the EEC connector there is a dead end plug that has a black round cap over it. Pull the cap off and tap into the single pin inside of the connector.
Works great I hooked up a really nice digital tach/Shift light on syP's old 95 MTX.
N
neg1ohs
Guest
anyways could u post a pic of that round connector?u sure im going to have that too on my 89?
