TT SHO PROJECT
So... my single t3 was to small to make any boost what so ever (as i expected) sooo i have a 16g mitsu turbo laying around, i am gonna ditch the twin turbo project for now as theres only a couple weeks left of good weather to mess around with the car and i NEED to get it on the road asap.
Ok the t3 was rated for 250hp worth of air (boooo hisssssss) the turbo spun up like a jet pretty fast, but didnt even make it to 0 vacume drove just like it was n/a...
so my fix for the problem is a 16g turbo i have laying around (and i know its good/makes Plenty of boost.. last boosted 18psi) the 16g is good for 350+hp of air and can be upgraded to 500hp of air flow=).. much better than the t3 and should spool up just as fast if not faster AND it has a built in oil restrictor (one less part i have to buy) the waste gate is set at 8psi is this to much for stock injectors? if so can i cut open the waste gate carefuly and cut a coil off the spring and weld it back together to lower boost?
ok with one problem "fixed" i come to another problem... How do you turbo guys fit your turbos under the hood?? the 16g bairly fits with the abs in the way and crruse removed. so do i...
1. remove the abs? and if so how is this done what parts are needed to convert it to non abs?
2. just heat shield everything near by? and if so whats the best way to do so?
and one more question... how do you rout your exhaust plumbing 2 into one.... do you run the back bank Up the firewall over teh tranny? or under the engine up the front some how? now i know the mitsu turbo sits diffrently than a t3 or t4 turbo as the exhaust inlet is ontop so is the oil feed... so i would need to run the exhaust crap right above the turbo and still have it fit under the hood (very lil room with the abs still there.... and the rad might be in the way too) any pictures of your setup would be nice just to give me an idea so i can get-er-done.
thanks in advance for any help as it is much appreciated
-Bob
p.s. i am gonna run it with both banks running the turbo instead of just 1 as i want the power to come on much earlyer (3200rpm on my 2.0L talon made 18psi so 8psi on the 3.0L should come on 2500rpm so i hope... anything to get power before 4 grand)
-Bob
