Woodyp
The Local Pick-N-pull just brought in a 2016 SHO. Can I pull the Sync system out to upgrade my 2013 to a Sync 3 and what all do I need to get?
Yes, you can pull it and use it. You MAY need ForScan. When I did my swap, I used 2019 which had the exact same options and didn't do any reprogramming. Check out www.naviupgrade.com they have some excellent guides. You will mainly need the USB Hub, Screen, and APIM. You will also need the USB Hub Adapter, USB Hub Harness, and GPS Antenna. Those are not factory parts though.The Local Pick-N-pull just brought in a 2016 SHO. Can I pull the Sync system out to upgrade my 2013 to a Sync 3 and what all do I need to get?
