Sync 3 upg what can I use from a 2013 SHO
Woodyp
Kansas City
The Local Pick-N-pull just brought in a 2016 SHO. Can I pull the Sync system out to upgrade my 2013 to a Sync 3 and what all do I need to get?
you will need something to get it to mate up. Maybe forscan? I think this has been documented a few times-- if you use the search forums link near the top it might pop up.
Ta2dResqr
Central Ohio
Yes, you can pull it and use it. You MAY need ForScan. When I did my swap, I used 2019 which had the exact same options and didn't do any reprogramming. Check out www.naviupgrade.com they have some excellent guides. You will mainly need the USB Hub, Screen, and APIM. You will also need the USB Hub Adapter, USB Hub Harness, and GPS Antenna. Those are not factory parts though.
Depending on your junkyard's price, the NaviUpgrade kit is $875 for a non-Navi system, which works great if you use your phone for navigation.
