bacernate
97 MONEY PIT
I finally got around to buying and replacing my valve body. Had a p1744 code before the tuner but not now. Even with the tuner wouldn't lock over 65mph.
As I pulled the vb off I noticed that 1 teflon ring around the pump shaft was gone. Vb scored inside the pump area, so I was looking at a pump failure soon I think. So I'm happy as **** that this might actually fix my car for 130 bucks instead of 1300. :woo-hoo:
Now my only problem is my local trans shop and local stealership don't have the teflon seals. :banghd:
So I'll keep you posted with a couple pics after I get some seals and put it back together.
I may order an updated pump shaft from sonnax if I have to get the seals online.
