swapping a used engine in , any video or book I should get?
shoisfast
NM USA
I have not done an engine swap since 1981 when I put a v8 into a datsun 510 .I am extremely rusty and have never even had the intake off any of my sho's.so is there a publication that details this procedure? and is there anything besides the rod bearings I need to replace ,also should I take it through the top or drop it through the bottom? thanks
SHOtimer
#2910
Santa Clarita, Ca
I just finished rebuilding and swapping a 3.2 into my SHO. I would say that a Helms is a must for a project such as swapping a motor.
Doug
SHOtimer
#2910
Santa Clarita, Ca
shoisfast said:
I used to believe chitons were better ,is that no longer the case?
I didn't say Haynes, I said Helms. Helms is the publisher for the Ford factory maunal. You can't just go to Kragen, Napa....and buy one. You can order them online. They run around $100 - you can't get better than a Helms, that is what the factory (dealerships) use.
Doug
Minnesho
i was wrong
MinneSHOta
SHOZ123 said:
The Ford Cds are cheap and in some cases free.
thats what I have is the factory ford CD, it is very detailed with everything i've ever needed to know.
