Swap
The Dude
pardeeville
Anyone ever try taking a supercharger out of a Thunderbird or Couger and putting it in a SHO. Can you use the MAF out of those cars also. Theres one of each at a junkyard around here. Seems like I could get alot of parts for a little cost. Anyone know the boost those SC put out?
jj94sho
T-Bird supercharger
I own a 91sc and it puts out 10-12 psi. Its pretty much stock. Hope that helps. I beleive the 94-97 has a better designed charger. Itd be alot of fab work but always possible. Good luck. :thumb:
The Dude
pardeeville
10-12 wow I wasn't expecting that much I'm impressed. I think I'm gonna go take a much closer look at it now. I looked at the cougar and the sc is mounted at the bottom with a long intake tube. So it was hard to determine what the sc actually looked like.
Make my own intake? If things go as they are in my head I plan on shaft driving the sc, I know there will be brackets to make. I'm assuming thats why you thought I would need a new intake, but yes I do want to mount it next to the stock SHO air intake location. Correct me if I'm wrong. This is just in the gathering info stage so all is welcome.
wood_e
The dude
Ames, IA
you can't use those MAFs. Look on SHOtimes there's an atrticle on there.
Anything is possible with enough money, but adapting a SC from a t-bird would be real tough... not worth it
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I has been done and was mounted on top it required a whole new intake.
Also a guy on here with a Dune Buggy did it with it mounted on the side. It didnt require new intake. Some one else is doing the same to their SHO now.
The Dude
pardeeville
I knew there would be others out there. Lets get some pictures of the work posted, or work in progress. What do you think the j-yard would charge for something like this, I'm gonna have to call and ask.
LOUDSHO92
Sponsoring Vendor
I got the blower for free..... I have plans for it....... :evilgrin:
You would need to check out NotSoSlows post on Superhighoutput.com: Here
Look up SHONuff93 and find his posts on it. I know he is currently redoing it.
silversho89
Whatever
Around
Umm, IIRC Super Poupes werent made past 95. :shrug:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
But GTPs were :naughty:
Im using a M90 off of a 1998 Pontiac GTP.
Much, MUCh more efficient than the early SC t-bird M90s. Plus, it has a built in bypass valve.
Im fabbing it up to fit where the stock AC compressor is (WAS) located.
Innercooled 10PSI right off idle should be fun :corn: :cheers:
