SV&HOdan, DVP
SHOspazz92
Banned
Triad Area, North Carolina.
I recently bought a wiring harness from Dan (SV&HOdan), It came quick and as described. I also bought 3 DIS's from him not to long ago...same story. A+++ Seller.
DVP - Bought a Reinforced front mount from him, came as described...etc. A+++ Seller
I think I bought some stuff from James (St Louis SHO) and Tim (Toolman) recently. I don't remember exactly what I bought (The garage is a pile of parts right now), but I'm sure it came one time and as described. :rofl:
-Sam
Dan rocks. I needed that harness :). If you have a line on another during your search could you shoot me a PM? Thanks!
JRA2000TL
The Complainer
Daphne, AL
x3 on that. Bought several things from Dan, including my rear seats for the 89. Great guy!
I'll keep looking, got a line on a few SHO's in the JY. If I find a 94/95 MTX I'll pull the harness for you.
-Sam
Thanks Sam. Been chasing my rear on this thing. Finally looked under the dash & it looks like previous owner installed some sort of aftermarket security system on this car. I think I have to yank everything.
SHOspazz92
Banned
I only got the engine harness from Dan, That ran from the Computer and ends at the CCRM. Is that what you need?
-Sam
boat
Likes blue ones
Tallahassee, FL
You will need the dash harness, and it has to match your year/trans, otherwise you will have some splicing to do.
I'm not 100% sure if I need one or both. The car has 75k and just had a 60k done a few months ago to address occasional stalling, with all sensors, plugs wires, belts, battery, h2opump, etc replaced. Still getting occasional bucking, tach to zero, stalling issues. going back for another cam sensor. However the car has issues maintaining idle under load. I have extra dis, pcm, ccrm and will tackle them and recheck alt... but I also think it might be a ground issue or maybe whoever installed this aftermarket security system (which I didn't know about when I bought it and may not be functioning) hacked up some wiring that might be screwing with things. frustrating.
SHOspazz92
Banned
Sounds more like a Cam sensor issue to me!
-Sam
I hope so. I just changed it out with new seals a few months ago. Idle dipping to 500 and below regularly has me worried there may be more going on.
boat
Likes blue ones
Tallahassee, FL
This sounds like an idle air control issue. Try changing that IAC out, then do the cam sensor, or vice versa.
Both on the list. Ordered a bunch of stuff from sho source today. Plus replacement for a rotted y-pipe that failed state inspection yesterday. Wallet hurts.
