Suspension bushings-where to get
fast4door
wichita
Was undermy car after doing the oil cahnge today and noticed alot of my rubber suspension bushings have seen better days. Is there any place that sells everything as a kit or is that just a dream lol
Joe
swami
No. VA
rockauto has everything you need at the best prices. use the discount code link found on the home page. you insert the code where it asks "how you found out about us" when you checkout if i remember correctly. HTH
fast4door
wichita
thanks for the link after adding it up i have about 300 bucks to spend there on suspension stuff lol. My car isn't a high mileage car but lived in Michigan most its life so that too a real toll on the under carriage
Joe
38SHO
#1 Oil Abuser
North Palm Beach
i'd also recromend some aluminum subframe bushings!
those, your control arm, and tension rod bushings will probably make a nice goal of stuff to replace.......
itwonder
VA
I recommend the 96 subframe bushing upgrade for much improved handling and less noise/harseness than aluminum. All of the parts from a discount Ford dealer are about $100. Numerous past posts on subframe bushing upgrades, so Search is your friend.
