I have the exact same thing happening in my 95 MTX. It's not like it surges up AND down, it's just that when I cruising along and I turn on anything that engages the A/C compressor, it's like I just ever so slightly increased the gas I'm giving the engine. ALL of my seals/sensors, clutches, wires/plugs, etc. are less than 1000 miles old, so I'm no thinking it's a deficiency or maintainence issue.
I think it's a PCM compensation curve kinda thing for when the A/C's on. The most annoying part of it it seems to run BETTER when the A/C is on, and by that I mean just SET to be on, not merely when the A/C clutch engages (if that made sense). Another way - it's like the engine has been given a little "boost" just in case the A/C happens to engage. I have NO sensation when at steady throttle of the A/C cycling - just when the EAC button has just been activated/deactivated (because the reverse is noticable as well.)
