Surge between 4-5k
shomike220
Chambersburg PA
Hopefully someone can help this problem that is fighting me. Under WOT acceleration when the car hits 4k you feel the secondaries open but the car kind of surges until it hits about 5k then it pulls like it should. It's basically feels like it laying down between 4-5k then it hits. The car is a mtx swap still running the d4ui and atx wiring. I have tired removing the c&l maf but it does not change anything. I have also double checked the timing. Any ideas?
SHOspazz92
Banned
Triad Area, North Carolina.
Are both secondaries opening when they should be? Open the hood, give the engine a rev and see if both open at the same time (At 3800, or whatever). They both operate off of the same vacuum source, but I've had one with a delayed opening due to a crack in a Vacuum line.
-Sam
shomike220
Chambersburg PA
-Sam
Yes I did check that and they are
are there any valid codes?
I would check plugs, wires, and coil as it sounds like it might be a weak spark type of issue.
shomike220
Chambersburg PA
I do have some junk rock auto wires I told myself I was just buying to get the car running that may be a place to start....gounna check the codes was away from
Home all weeked
