Super Noob Question
jpSHO
Massachusetts
I hate that beeping scanner it takes forever to get the right codes. I used it for three years and it sucked. I can't make any sense out of these codes. I do remember that they repeated them selves and that there is a beep in between codes. You might be adding a spacer beep in with an actual code. The 1.1.1 isn't a code but I forget what it means sorry I couldn't be more help. I would scan it again and remember the codes repeat them selves. I'm thinking 1.2.1 is the only code you have. I think 4.3.3 actually 3.3.3 and again that stands for something but I can't remember what. The 121 code has to do with the tp sensor but I would scan it again to double check.
sickSHO96
Louisville, KY
All I know is that your cracked control arm is a fatally serious issue. The more you drive on a cracked control arm, the bigger the crack gets, until the whole thing snaps and your wheel is sitting behind your car somewhere. If you're going fast enough when it happens, you could die - no shit. This actually happened to my brother in his Z26 Beretta once before, but luckily he was practically stopped when the thing snapped off. If he had been on the interstate he would not be alive right now, as it was his FRONT control arm that went bye bye, and that means no steering input OR wheel there to steer with at all.
Moral of the story - GET YOUR CONTROL ARM REPLACED!!!
