Super Easy Way to Clear KAM
Dirk37
Mr. Resourceful
Washington
While fine tuning my MAF yesterday, I was getting real tired of removing the battery terminal to reset the KAM. I started searching around and found that this connector goes right to the ECU! All you do is disconnect it for a few seconds and reconnect it and bam, the KAM is cleared. The best part is it leaves your radio settings intact :woo-hoo:
Definitely didn't see anything like that on my '95 ATX. Did have a separate wire coming off the negative terminal.
SHOspazz92
Banned
Triad Area, North Carolina.
If you're tuning with a QuarterHorse or TwEECer, you do realize you can just load a non SHO run file (Like a Mustang A9L...or whatever) and turn the key to on. Turn it back off and load whatever X2J File your tuning and the KAM's are cleared. In fact, I have a "Clear" (Mustang A9L) file loaded in to one of the position switches (TwEECer) on my SHO for just this purpose (With the other 3 being "Off" , "N20" and "Track".
Ishodu
Same here this works the best.
yamahaSHO
E85 whore
Arkansas
That's what I always did. Don't even have to get out of the car. ;)
