Sunroof leaks from drain tube....HELP!!!
groove83
PimpTempoOwner
Kalamazoo, MI
Hey, I was wondering if anyone has had a problem with the drain tube on thier cars? I bought a 94 atx that I am going to start fixing, and the drain tube on the front drivers side is busted... the actuall hose that goes down the A-pillar and drains out. I was wondering how you take it out of the a-pillar and replace it, cause as much as I tug, it doesn't come out.
any help (pics..) would be greatly helpfull.
drew1095sho
port jervis ny
I know it's not a fix,but being that there are two drain holes in the moonroof,I simply plugged off the one that was leaking,and the water still drained out of the other drain. My drivers side was leaking and soaking the carpet,so I just plugged it off and now I have no problems with a wet floor carpet.
1995 MTX Blue.
SuperHO
Mental Patient
St. Joe, MI
the driver's side WAS plugged off (used to be my car). When I bought it, it leaked...after further investigation, there was a freaking pen stuffed in the drain tube. Yeah....that didn't really work..
ohfosho
ontario SHOwner
ontario, canada
there are 4 drain tubes in total. easiest way is to block one. next easiest way is to run a smaller tube down the original, and seal it to the top with silicone...
red89SHO
WI
I found the 2 in the front where are the other 2?
crystizel
