Sunroof Issue!!
Derick
Trevor,WI
Anyone Know if there is an adjustment on the sunroofs.My sunroof stops and its not all the way up. I have to let off the button and tap it until I can see that it is even with the roof...lots of wind noise and sometimes Water :confused:
I went to Ford and they said "We don't do sunroofs"
Thanks FORD...
Any help Would be Much Appreciated thumbs_u
Happy New Year To all you SHO nuts out there...
BlackOnBlackATX
Dutchess County, NY
i know in the chiltons manual theres a removal procedure, i would imagine you would have an easy time figuring out how to line it up if you took it out.
projectSHO89
SHOless In St L
If it is the factory moonroof, the service procedure is in the factory service manual. If it is an aftermarket sunroof, the dealer won't likely touch it. Find a a shop that specializes in them.
Is it a factory roof?
Steve
K-BL
I dabble
Greenwood, USA
move the moonroof all the way to the complete open position. When its completely open look at it from the outside in. There are 3 screws on each side that adjust where it "sits" when not activated. just move those around till you get it right.
K-BL
Well mine leaks really bad on the '93. The drains are all open but it just pours into the car at the car wash. Is there a gutter or something to keep the water out of the interior? Something must be wrong or missing.
Paul, where is yours leaking?
I've found mine leaks at one corner when really soaked with the hose at particular angles. I wonder if over the years some sludge builds up in some of the drain tubes? Or more likely if there is just a finite amount of water that can be drained in short periods of time by these drains and, since it's not completely sealed, some gets through. Maybe a combo of both.
I've never experienced leaking while driving in the rain including heavy downpours.
<small>[ January 02, 2003, 10:36 AM: Message edited by: luigisho ]</small>
Mine leak along the back and at the rear corners. I have flushed the drain tubes out and they work fine. It appears that the water is just coming into the interior instead if going to the corners where the drains are. The car has been rebuilt but I don't know where the damage originally was. Either something was left out or the there should be a upward bend at the edge.
ottosho
michigan
I have found that silicone caulk will stop most sunroofs from leaking. I prefer the clear stuff....
pjtoledo
'ol man in the SHO
toledo,ohio,usa
Derick:
,,,,,, :confused:
Thanks FORD...
Any help Would be Much Appreciated ,,,,, :
Next time be sure a sales person is part of the conversation. Then ask the sales person why you should buy a car from him if it can't be serviced properly. Ought to be an interesting conversation.
Perry Toledo,Ohio
Modemagic
Davenport, Iowa
Having installed MANY different types, models, and versions of sunroofs for a few years, I can give u a pretty good idea of what is wrong.
If u have a factory sunroof, (Full power model) then there is several things to check. First of all understand that the rubber gasket around the glass is NOT designed to seal up and not leak. It is more of a wind/road noise preventer and to slow down but not stop water. This is why the basket, (the main framework of the roof, trackwork, etc.) are smaller than the hole in the roof of the car, as well as having four draintubes at the corners. If the rubber seal does not touch all the way around, you have two options: 1. cut a SMALL hole in the seal, and slide in thin gauge wire. This can help fill out the seal. 2. replace it. More expensive than the earlier, but probably better.
There are several things to check, most of which are easy to do. Keep in mind this is all easier to do with the headliner out of the vehicle, but can be accomplished with the headliner in the car. You can pop off the draintubes and pour some water down them. I used a pressure spray bottle when I installed sunroofs professionally. What happens is junk can clog up the tubes (leaves, rocks, etc.) as well as algae, mildew, bugs can decided to start growing in there. If you pour water and it does not drain as fast as you pour the water in, check for kinking in the hoses, and/or replace them.
The basket of the sunroof should rest slong the underside of the roof of the car all the way around the car. If it doesn't bust out some silicon and make it so. Thinking back on my Wabasto sunroof training, it was actually standard procedure to use butyl instead of making the basket taller, reason being of tweaking the metal of the roof. If the car was wreaked, it it is possible that it does not sit right.
If you need to adjust it, the glass has metal brackets mounted on the sides which line up to holes on brackets on the trackwork. If u loosen up the screws, u can slide the sunroof glass up and down accordingly, just line it up to the roof, tighten them down, and be done! :)
If the sunroof is a "slider" or "pop-up" they only leak in one or both of two places. The seal where the glass meets the seal. Or the seal where the plastic housing meets the roof. Either way with either of those two roofs, and I wouldn't recommend a rookie trying to tackle either of those jobs without someone experienced helping them out. I'd give u all the guidance I can though! :)
Hope this helps you out and gives u direction with your roof!
