The rear passenger side of the sunroof is higher than the rest, reason for concern?
Thanks, pics below.
First 2 problem?
Second 2 flush.
Thanks, pics below.
First 2 problem?
Second 2 flush.
I believe there up now. But could be wrong.i don't see any pics
It can be adjusted to sit flat.
Put the glass in vent, unclip the accordion blind/trim things on the left and right, close the glass, adjust as necessary, torque to 44 lb-in.
Re-initilize the roof. Turn the ignition to run, hold the tilt switch till you get full vent, then push and hold the vent switch until the glass motor stalls for 3 seconds and continue to hold for another 5 seconds.
You may want to do the initialization with the engine running to keep battery voltage up.
Thanks for the awesome reply!!!
My wife will leave me alone now, ever in the Mobile/Pensacola area first round is on me
