StormMountain
1995 SHO
I have a stock 95 SHO 3.2L. Can anyone suggest modifications that I should consider? Any priorities?
-Tony
-Tony
Big Bore Butterflies, Port and Polish Intake, Y-Pipe, Exhaust for starters.
-Tony
a gen3 subframe is a very good, inexpensive and worthwhile upgrade. if you are planning on any other upgrades that should be in the 'pre-requisite' category, along with all maintenance, imho.
You need to get a subframe from a 96-06 Taurus along with the lower control arms, steering knuckles, rotors, calipers, and ABS sensors. Optionally but very highly recommended you can get the steering rack from a 3rd gen (96-99) SHO. The subframe will bolt directly to the body and on the automatics I think the only thing you will have to modify to mount the engine/tranny to the subframe is the hole for the front mount. Your existing struts will mount to the new knuckles.Can you give me any direction on the gen3 subframe upgrade?
