subwoofer not working!
randy'sho
95 White MTX
High Point, NC
I am in the process of redoing my stock jbl system that the PO cut out! I found that the stock subwoofer was blown, so I cut the hole out and installed a 10" rockford fosgate that I had....I have everything working properly except for the sub....I have power to the sub amp, but nothing is coming out of the sub! any ideas for me! I know the sub is good so that is not the issue! But I am stumped!
shoofff1
shooff
missouri
is the stock speaker amp plugled into the sub amp. a wire goes from the speaker amp into the sub amp like a high levle input
shoofff1
shooff
missouri
chech the wire going from the sub amp to the sub and make sure its not damaged
Vnuk1
Mr. Mayhem
Minnesota
Well if the sub has power but no sound it makes me think its not getting signal from the amp or the Head Unit.
randy'sho
95 White MTX
High Point, NC
did that man! if I test the wires on the subwoofer should I be getting any power? I guess that is a dumb question!
randy'sho
95 White MTX
High Point, NC
sub doesn't have power but the amp does! does anyone know what color the sub wire is going into the headunit?
shoofff1
shooff
missouri
I think its a harness going into the stock head unit im not sure when I got my sho it didnt have headunit in it let me research and find out what the problem is
randy'sho
95 White MTX
High Point, NC
yeah the PO had a mess with the wires! some cut some new.....alpine head unit! I went back to the oem! I know that I have all the proper wires back together though!
shoofff1
shooff
missouri
crack open the amp and check the solder points for the wire coming out if there ok take a volt ohm meter and see whats coming out it could even be a bad capacator in the amp
Vnuk1
Mr. Mayhem
Minnesota
Not off hand, Does the manual have a diagram for the JBL system?
VNUK1SHO
Alter Ego
Champlin,Minnesota
Here I took some pics of mine its a 93 and might be different from yours.
Now the two black wires you see on the left side are going to the subwoofer.
randy'sho
95 White MTX
High Point, NC
thanks man, where does the wires that come from the little black box that sits between the two amps go? that is my only issue, the connectors don't mach up!
cobrakidd03
michigan
[/IMG]Here is a couple more pix.
[/IMG]
I remember when i bought my first SHO it did not have the jbl in it. I added it but did not use the black box that sits between the 2 amps.
cobrakidd03
michigan
Hope it works out for you. Vnuk1sho, I feel your pain. Im 5'7" and it was not to pleasent taking the pics i did. I also have my sub box and new amp in the trunk that i did not want to take out.
Vnuk1
Mr. Mayhem
Minnesota
Yeah the nut that holds the trunk latch to the lid the left one fell off somewhere and now is a pain in the ars to open the trunk. Sorry Randy'Sho I did not get the top of the black thing for you, could not get a good angle on it.
