thecrew2999
3.2 MTX SHO
i had to do some modifactions to my subframe and i wanted to know if this would hold.
well im guessing my car been in a wreck before from all i can see and the atx subframe that was on it has been bent at the front passenger side so the bolt went in angeled.
well anyways since im on the atx to mtx swap i went to put in my mtx subframe and it didnt wanna line up on the last bolt and its got solid subframe bushing so that made it harder.
well anyways i cut some of the unibody out so the bolt could go up threw straight for the subframe to connect on all 4 corners and i used a big square washer and a nut that would fit it properly.
i had to cut down about 1 1/2 inch to get the holes to line up.
my question is will this cause me problems later on or should it be strong enough ?
