Subframe recall and ALSFB
1993MTXSHO
Its a Taurus...
Jersey
I want to get the alsfb but Im nto sure if I need a recall kit or not. My car has had the recal done but how do I know if I need another recall kit for the front?:thumb:
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Usually its only the rear thats mostly needed.
Worst in the rust belt area. Best thing is to look at it once in hand , send us a pic!
Paul
Guest
Hilltop
If the bolts are rust pitted their strength has been greatly compromised. The original frame nuts are definetly real crappy and prone to spinning on removal if rusted. There is'nt a rule that says you need to use the upgraded ford fasteners. You need to consider reasonably high grade fasteners that don't need to be metric to make a safe fit.
Minnesho
i was wrong
MinneSHOta
the recall kit has a lot beefier captured nuts, and besides new hardware is always much nicer to work with. my 92 and 95 have had the rears replaced on the recall, and when i put the ASFBs in i went ahead and replaced the front hardware as well. the kit was around $20 from ford.
