DemonNeno
SHOCAGO Freak
Now this is insane! I installed Delrin bushings on the SHO about a month ago or so. When I tried to remove the left front bolt, it only came out 1/2 way and just freely spun. I later found the nut was all broken up and no longer holding still. Solution? I just heated the bolt head off and installed a 10.9 grade bolt w/ a nut and a couple of washers, including a lock washer. Now, I lifted my SHO up to do a quick retorque job and make sure all was snug. Well.. My right front one is starting to spin "freely" now too! Are the front nuts & bolts prone to the rusting apart problem as well? if so, how can I install the nuts for the bolts from the ford recall kit? Do they make one for the front?!
Neno & The '91 Dark SHO
131K Mi., Black on Black/Mocha Interior, '94 Mark VIII Rims, 225/50R16 Yokohama A540s on front, 225/50ZR16 Comp TA ZRs out back, Rod Shifter Converted (Broken stabilizer bolt, still sitting in my trans housing!), SHO Nut Reinforced Motor mounts, Inner air box removed, 3.2L larger crossover tube for intake installed (sure did make the intake LOUDER!), Delrin SFBs, a seriously leaky exhaust system!
Ready To Install: Subframe Connectors and Eibachs (waiting for more suspension $$$!)
Coming Soon?Konis/Poly setup
