subframe bushings during clutch job?
Bank of SHO
Vegas
I'll be replacing the clutch soon. Is this a good time to replace the bushings(i.e. while the subframe is out and away from the car)?
I'm thinking about going with aluminum bushings. Do they cause premature wear on any other parts?
Yes, I did a search. Looking for any and all advice.
Thanks,
Tom
shojuan
sunny San Juan Bautista,
It's a very good time to replace the bushings. Not it should stop anybody not getting a clutch installed from getting new subframe bushings. When doing the clutch your will have very little work to do installing the aluminum bushings. In fact ordering the bushings might take more time!
To answer your other question, my guess is that 95% of the people with aluminum subframe bushings like them.
One thing I did when I installed my bushings was put a layer of grease on all the metal to metal surfaces to possibly dampen any noise, vibration, and harshness. I'll see if I run into any adverse problems with that, but I doubt it.
jelloslug
Digital
Greenville, SC
There is really not other better time. What other time are you going to have the subframe dropped? If you think you might want to replace the steering rack you might want to consider doing that while the subframe is off also, it's a PITA to do with the subframe in place. Also, motor mounts are a breese to do with the subframe out of the way.
shojuan
As far as subframe alignment. 1/2" EMT electrical conduit is just about perfect...very close to 3/4" OD. A 10 foot section cost me $1.25. If you don't have a truck and don't want it sticking out the window then take a hacksaw with you to the hardware store. And the piece I used for alignment was 18 inches. It provided more than enough leverage to pull the subframe maximum forward for maximum positive caster after I used it to align both holes in the front. thumb
srfdude
Oceanside, CA
Rick, after getting the SF lined up, how about lining up the engine/motor mounts. The holes through the SF are huge, twice as big as the bolts. I wonder why ford didn't put some bushings through the holes; just doesn't seem right to me.
Mike
