Subframe Bushing
It's SHO Time
Gillette, Wyo
Well when I replaced my tranny like 3 monthes ago, I went to put the passanger rear subframe bushing in after I just ran the bolt up a little and now I cant back the bolt just keeps turning and you can hear the nut hitting the sides of were the nut is. I hope you guys know what im talking about and can help he out a little. Do you think I should weld a nut on the outside of the frame thing where the nut is and then run the bolt up with the bushing, because right now I dont have the bushing in and am getting tired of the squeking noise.
thanks,
Justin
Mike Kopstain
Arlington Heights, IL
Bad, bad idea to run without a bushing in. We had to cut a flap in a subframe because of this put a couple welds on the nut.
Good luck. It's not fun any way you look at it. frown
It's SHO Time
Gillette, Wyo
Why is it bad to run with out the bushing? I just got back from a 350 mile rode trip with it and it ran way smooth and no problems, and I got AWSOME gas milage.
Justin
DJ SHO
NY
94taurusSHO:
Justin
It's just not safe. Period. It's like driving around with only three lugnuts. Not a good idea.
SIREDZO
BOSTON MA
I just did mine and the bolst fell in side :mad: i cut some flaps too and put some vise grips on the nut till it tightened and the nut will catch the notch in front. you will be all set
